pickmari
#1 Posted : Thursday, September 15, 2016 5:00:32 PM(UTC)
pickmari
My water dispenser is not working. When I press dispenser switch the pump in rear activates and pumps water to inside of door to second water valve. (manual calls it water cooler valve). So, I used a volt meter and determined that I am not getting any power to this valve. Does any one have any idea how to fix this problem?
pickmari
#2 Posted : Thursday, February 9, 2017 10:16:00 AM(UTC)
pickmari
It turns out that the wire running down from top off door to the water cooler valve was broken in half. The constant opening & closing of door caused it to break. Was able to run new wire and have not had a problem since.
Kenmore Elite refrigerator water dispenser does not work (Refrigerator & Freezer Repair)
by MikesrAPP 9/13/2016 7:14:53 AM(UTC)
