blm1964
#1 Posted : Friday, February 13, 2015 8:46:20 PM(UTC)
blm1964
Kenmore elite commercial freezer has suddenly stopped getting cold. Fan, light and compressor all come on but it only blows warm air. Have changed the thermostat and temperature control. The compressor is hot to touch. Does anyone have any idea on what I should be checking next?
#2 Posted : Saturday, February 14, 2015 1:01:20 AM(UTC)
Sounds like you have a sealed system problem.
If the compressor is running the unit should blow cold air into the freezer.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
Dean Haustead
#3 Posted : Wednesday, February 8, 2017 11:23:29 PM(UTC)
Dean Haustead
I think you should check the rubber of the door of the freezer. If it is loose from the door the freezer will be no cooling enough.
