tdking1327
#1 Posted : Wednesday, February 8, 2017 1:51:32 PM(UTC)
tdking1327
What does LF code mean
PNWDrew
#2 Posted : Sunday, February 12, 2017 10:35:40 AM(UTC)
PNWDrew
Need complete model #. But LF is usually long fill. Meaning perhaps the screen in the machine valve or at one of the hose ends is clogged. Turn off your house valves behind the washer and disconnect the cold hose from the machine. It's usually the cold unless you've had a new water heater installed recently.
Quick test is to start the machine on any cold fill cycle, if it isn't filling or is very slow that's the cause.
Use a mirror or get behind it to see if sediment or other gunk is blocking the screen in the valve where the hose would screw on.. If possible don't remove the screen and be gentle cleaning this as you DO NOT want to damage the screen or allow anything to get through that screen where it could jam the actual valve.
If that's clear put the free end of the hose into a bucket or the basket of the machine and turn house valve back on. If nothing comes out then maybe there's a clogged screen in wall end of hose.
barona1
#3 Posted : Thursday, July 27, 2017 8:34:44 PM(UTC)
barona1
Change the small black hose which goes from the tub to the water level sensor.
I guarantee this is the problem
The hose will have a hole in it.
The hose is about $20 and the replacement can be done from the rear inside on the left side.
The water level sensor is high up on the left side.
The black hose is attached to the bottom of it.
The other end of the hose is attached down low on the left side at the tub.
Remove the wire tie at the side of the tub.
This exact spot is where the hole will be.
Do not wire tie it.
Just let is dangle without being tied.
Once it is replace, it will work perfect!
PNWDrew
#4 Posted : Thursday, July 27, 2017 8:54:53 PM(UTC)
PNWDrew
This is an old post... I'd guess my answer already fixed it. Maybe your post will prompt an answer from OP.
Whirlpool Washer Duet LF code (Washer Repair)
by bwclark47 5/2/2016 7:10:32 AM(UTC)
