I tried defrosting, snaking and probing to clear a blocked drain with no luck. I hooked up a small air compressor to the bottom tube ( above the drain pan) and 2 seconds later i heard something fly out the top ( in the freezer). the door was open so i have no idea what it might have been, but its clear now
