Jimbarneskauai@gmail.com
#1 Posted : Friday, January 20, 2017 9:50:43 AM(UTC)
How to get to the burner to change the fittings for LP gas? What to take off first? Then second? Third etc.
thorning
#2 Posted : Saturday, January 21, 2017 1:00:00 PM(UTC)
thorning
If you are going to convert this dryer to LP gas I suggest you order the parts first. Instructions for the conversion should be included. You will need to take off the front cover and remove quite a bit of hardware. GE dryers are not very convenient to work on however and if you are not familar with the parts you may need to have a person help you who is familar with GE units. First take off the front cover then remove the drum. The gas valve may be accessible without taking it out of the dryer but probably not. After you change the orifice and the limiter plug reverse the procedure .
