LG WM2301HR Front load washer. Bearings went on it and With APP I had my parts quicker than expected. The bearing seperated upon removal, and was a B to get it out. Long story short I spent too much time on the old bearing and couldn't finish same day. Today I got the bearing out, new parts in and the tub put back, drain hoses connected, and i notice these 2 mushroom looking parts. I checked the diagram they are listed in the parts list as washer water inlet valves (error by LG?), but not pictured in the diagram. They are referred to as Floats on this site. LG Part #: 4769ER4001A for one of them, there are 2. Little rounded plastic caps with a rubber stem on the underside. I just need to know where they go. I don't know how they got on the floor next to my tool bag, but I'm pretty sure if they weren't important, they wouldn't be there. Any help is appreciated, thanks in advance. JeremyEPHVACR attached the following image(s):
Groups: Expert
That's exactly what it is. Thank you sir. All working, and quietly at that! Thanks for taking the time to help out. Appreciated!
