Roger57
#1 Posted : Saturday, January 14, 2017 1:50:02 PM(UTC)
Roger57
Turned oven on the other day turned my back and heard a pop! I knew that did not sound good. Oven will not come on. Broiler works fine as do the burners on the top surface. Opened up the oven today to repair what I thought was just the igniter needing to be replaced. As I took it out I noticed a bare wire that may have caused it to short out? I replaced the igniter but did not fix the problem. Control panel is all lit up. would there be a fuse anywhere on this unit?
Whirlpool oven will not light (Oven Repair (including Ranges and Cooktops))
by firefite44 8/3/2010 2:32:28 AM(UTC)
