circuitcide
#1 Posted : Thursday, January 5, 2017 10:06:04 PM(UTC)
circuitcide
I bought a small oven, the Ktichenaid KCO275.
It has an internal speaker that loudly sounds for any input you give it.
To silence it I took it apart. As I was unsure where the speaker was I plugged it in to listen. While twisting an input knob the control board shifted and made contact with the frame.
My guess is that this created a short as I heard a fuse snap and the unit went dark.
Now I need to find and replace the fuse. Then find and remove the speaker.
I have no idea where the fuse is, my guess for the speaker is the round black element on the control board labeled BZ?
UserPostedImage
ThatGuy
#2 Posted : Friday, January 6, 2017 1:23:08 AM(UTC)
ThatGuy
Groups: Expert
United States
BZ would be buzzer or piezo buzzer. Yes it makes noise.
I hope your boards survived. Follow the power cord coming in. One side should have a fuse holder on it. Always replace the fuse with the same type and amperage.
circuitcide
#3 Posted : Friday, January 6, 2017 1:24:47 AM(UTC)
circuitcide
There is no fuse.
Would the boards be available as parts?
ThatGuy
#4 Posted : Friday, January 6, 2017 7:26:27 AM(UTC)
ThatGuy
Groups: Expert
United States
It might look like this. I thought I could see the edge of one on the far right of your pic behind the circuit board.
UserPostedImage
circuitcide
#5 Posted : Friday, January 6, 2017 3:54:26 PM(UTC)
circuitcide
Thanks for the help.
It turns out this model does not have a fuse. Power comes in, through a resistor and the 2 diodes. Then out the drain of the switching voltage regulator.
However, much simpler is the fact that I tripped the GFCI on the wall power outlet. After a re-set it now powers on.
