2 Pages<12
thorning
#11 Posted : Monday, November 10, 2014 7:04:14 AM(UTC)
thorning
I have a Maytag natural gas dryer model LDG7304 AAE that I just rec'd from a friend who said it needed repairs. It had a worn blower wheel hub so it would turn but made a lot of noise. I repaired it and went on to find the door switch was suspicious in that the terminals were slightly burnt. Replaced it and went on to try and get it to provide heat. Found the thermostat on the burner tube (presume this is the hi limit one) was broken. Replaced that with a spare from another dryer and it fired up but would only stay lit for a short time then it would cut off the gas. I AM USING PROPANE TO TEST BUT HAVE THE NATURAL GAS ORIFICE STILL IN PLACE). It gets pretty warm but only runs a short time before it shuts off. I bypassed the hi limit t-stat and it works fine. The igniter works OK and the flame sensor appears to work OK. I cannot hook up to natural gas easily for testing and I am wondering if the propane gas heating using the nat gas orifice is too hot and causing the hi limit t-stat to signal the valve to shut off prematurely. If I wait a while I can restart it but the flame goes out quickly unless I bypass the t-stat. I am going to install a new set of gas valve coils ASAP but need to get some ideas about using propane w/o changing the orifice (for my testing) . Can anyone advise if this has happened to them.
thorning
#12 Posted : Tuesday, November 11, 2014 3:11:36 AM(UTC)
thorning
Bought and installed a new set of gas valve coils and problem persists. The gas valve will turn on and it fires up OK the 1st time but after it shuts off and tries to refire the gas it chatters a bit and will not fire. Igniter is heating OK. I may try a different igniter from another dryer that works fine and see what happens Can anyone help on this problem ?
Steve777
#13 Posted : Thursday, December 29, 2016 12:35:15 PM(UTC)
Steve777
I am having a similar problem with my HE3 Kenmore gas dryer, and I was hoping someone here might give me some ideas:
With the vent disconnected, it works fine. Gas comes on and burn cycles are 3-5 minutes. If anything is connected to the dryer vent, even just our short length of 4' of flex hose, the dryer never reaches normal temps and the burn cycle is about 1 min long.
Seems like a vent blockage issue, but I have cleaned out the vent pipes (they are only 8' long or so) and blown air thru it from a shop vac and they seem clean. And even the short length of flex hose by itself if connected will cause the burn time to go down (and yes I have looked thru the flex hose and it is clean too).
I tried replacing the solenoid coils, and it made no difference. I also have cleaned out the lint from the dryer ducting, at least the places I could reach without major disassembly.
Since everything appears to work fine without any connection on the vent, I am assuming that all the sensors are OK. If not, can someone suggest which ones might be involved here. And there is still air flowing when the vent is attached, enough to open the louvers on the outside air exit, and enough to feel from the end of the flex tube when it is just that.
I considered that it may be that the blower is just not moving enough air, that it is OK with nothing on the vent but even the slightest additional air restriction causes issues. It would make sense, but how can one test that the blower is moving enough air? One other thing I thought of was perhaps there is an air leak internal to the dryer, and it is not sucking enough air from the heater assembly, such that when a vent hose is added it gets critically low. Again, not sure how to test this hypothesis.
Any thoughts or suggested test would be appreciated.
ThatGuy
#14 Posted : Thursday, December 29, 2016 1:24:24 PM(UTC)
ThatGuy
Groups: Expert
United States
Propane and natural gas are two completely different pressures and not at all interchangeable.
Yes the flame is way too big on propane and God only knows how many BTUs over the limit it would be. Stop it!
ggarnett
#15 Posted : Saturday, January 7, 2017 5:17:52 AM(UTC)
ggarnett
I've got a very similar problem with my kenmore elite HE3. Although I don't feel like the flame is wimpy, it just doesn't stay on for more than 10 seconds. I've replaced the coils, gas valve, thermistor, moisture sensor bars and checked the flame sensor, high limit switch, and I think everything else for proper resistance or continuity. The exhaust path is clear and the dryer is cleaned out. It even does this with the dryer vent hose disconnected. I never tried the ignitor, because the flame always re-ignited! But it keeps going off like yours and would never get clothes dry. Could that be it? I was getting ready to buy a new computer module. Like some of these other guys, I'm running out of part s to replace...
G
Steve777
#16 Posted : Sunday, January 15, 2017 5:56:12 PM(UTC)
Steve777
Well, think I have narrowed down my problem.
I noticed that the dryer door does not stay fully closed, it would push back open 1/4 to 1/2" after clothes hit it for a while when the dryer is on. Did some experiments: If I lean on the door to keep it fully closed everything is fine. As soon as I stop leaning on it the door moves out a bit and the next cycle is short. If I lean on it again back to long cycles. I tried keeping the door in with a bungie cord and that works too, long flame cycles and fully dry clothes.
So it would seem to be a latch and/or seal issue with the door. I will be looking into that, but that seems like the root of the problem.
Guest
#17 Posted : Saturday, October 9, 2021 1:56:34 AM(UTC)
Guest
Rank: Guest
United States
I have a LDG9304ABE dryer (approx 25 yrs old). Has been a great appliance with no troubles at all...now it does not generate enough heat to dry a load of clothes. When starting, the burner will ignite for about a minute then goes out and does not reignite. The gas connection was upgraded to code, we replaced drum rollers and belt and cleaned/vacuumed everything.
No lint or airflow issue at all.
I'm hoping to get some direction on this as opposed to just starting to swap parts...
Thanks..
Guest
#18 Posted : Saturday, October 9, 2021 2:00:30 AM(UTC)
Guest
Rank: Guest
United States
Thanks..
Guest
#19 Posted : Saturday, October 9, 2021 2:01:19 AM(UTC)
Guest
Rank: Guest
United States
Thanks..
Guest
#20 Posted : Saturday, March 2, 2024 1:19:24 PM(UTC)
Guest
Rank: Guest
United States
Can gas coils stop a igniter from glowing?
Guest (10)
2 Pages<12
