atamhank
#1 Posted : Thursday, December 22, 2016 6:48:39 AM(UTC)
atamhank
My dishwasher has a strange problem. IT does not stop!!!
As soon as the lid is closed, the circulation motor gets on and keeps running in the background. The front panel cycles can be selected as normal and at least on the panel it proceeds through the wash and dry then clean status buttons as expected.
However the circulation motor keeps running and never stops.
Changing the control board twice and it fixed the problem for 3-4 weeks and it re appeared exactly as it was earlier. Not sure if the control board that was replaced was having quality issue or some other thing is real issue.
Did anyone have similar issue? What was the culprit?
atamhank
#2 Posted : Thursday, December 22, 2016 6:52:42 AM(UTC)
atamhank
Also I would add that the dishes are wet and do not get clean, Wehn opening the door the water drips on the dishes from the jets.
atamhank
#3 Posted : Sunday, January 22, 2017 10:35:58 AM(UTC)
atamhank
I got the issue fixed by replacing the main control circuit board. It worked perfectly for 1 month and the problem reappeared exactly as before the board fixed it.:( (The dishwasher starts and continues to run until the door is opened again. while the front panel button work as expected but the background motor keeps running as long as the door is closed)
As the board was under warranty, I got replacement and put that one in. The problem got fixed again.:mad:
However after about a month the same problem re appeared. Very frustrating to know what component is causing the board to fail after one month. :mad:
Anyone had any experience with this issue? :mad:
