Frigidaire oven Model #PLGFMZ96ECC - Oven wouldn't heat but broiler drawer would. Now neither heats but burners still ok. Checked the igniter & it crumbled to pieces. Replaced the igniter still no lighting or call for gas. Pulled the RTD and it's reading right near 1100 ohms at room temp. Put the RTD back in and now getting a code that it's shorted. And of course still no heating......
Any help would be greatly appreciated - thanks!
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
So the glow ignitors never glow?
They should have 120 volts going to them. If the voltage is missing, you are going to have to trace it back to the control board/computer. If the voltage is missing at the control, then you have a bad control board.
