hello my ice maker not making ice. so I replace the control module and the serrandier..now it does making. But making ice very little..Like the hole entile day, only make 10 piece of ice. What is the problem..Thank
Groups: Expert
If the icemaker is working, but slow, its usually a sign that its not cold enough in the freezer.
It needs to be below 10 degrees Fahrenheit in the freezer to make ice reliably. If its cold enough, the icemaker should cycle about every two hours.
Did you check the water inlet valve?? I had the similar situation and the problem was with the water inlet valve. Check the water pressure in the valve, it should be at least 20 psi. If the water inlet valve has sufficient pressure but the ice maker wont make ice, you should change the water inlet valve.
