Robert McGinity
#1 Posted : Sunday, December 18, 2016 10:39:09 AM(UTC)
Robert McGinity
I have a Maytag gas dryer model DG412. It seems to be too hot while drying. It has even softened a button on a pair of pants so much that it came off by breaking out the center where it is sewn on. I do not know if there are upper and lower temp thermostats in this unit or not. If so, which one is it and where is it located.
ThatGuy
#2 Posted : Sunday, December 18, 2016 11:05:52 AM(UTC)
ThatGuy
Groups: Expert
United States
Make sure you have good airflow to the outside.
There are two thermostats that control the temperature. A low and a high one.
The low is a 140, the high is a 150 degree t-stat.
Whirlpool WPY304475 Cycling Thermostat 14 - AppliancePartsPros.com
Whirlpool WPY304474 Cycling Thermostat 15 - AppliancePartsPros.com
They are both mounted on the front side of the blower housing.
Parts for Maytag DG412: Motor Drive-Thermostats Parts - AppliancePartsPros.com
