Hello all, I am trying to troubleshoot gas dryer heating problem but need some some help first identifying the dryer and opening it up. The model number is rubbed off and i am not sure where to start to get it open. I tried using a putty knife above the front kick panel but do not seem to find any release latches Can anyone look at the picture collage and give me some clues on how to open it to start troubleshooting the heat problem? pokey302 attached the following image(s):
Groups: Expert
I think your model number is 417.94052500
ThatGuy. Thank you so much. After searching that model a bit I can confirm that that is definitely my model. I found a manual for it and see that I was nowhere near where I needed to be in order to get that kick panel off. Thanks again for the help!
Groups: Expert
