BryceB
#1 Posted : Tuesday, September 6, 2016 9:27:19 AM(UTC)
BryceB
I have an LG, French door above/freezer below, refrigerator - LFC25760sb. I have a problem with the lights that appears to be a short somewhere. The relevant facts are:
1. The two lights in the fridge come on intermittently, sometimes flickering. The bulbs are good and are screwed in tightly.
2. The freezer light is also involved in the problem. It doesn’t flicker but it is sometimes on and sometimes off. At the present time, the freezer light works fine but the fridge lights are off. It seems like the problem may be back in some connection that supplies power to both lights.
Thanks for your help.
Dean Haustead
#2 Posted : Friday, September 9, 2016 4:50:33 AM(UTC)
Dean Haustead
Light is the important thing in refrgretor. check the bulbs properly when you buy your refrigertor.
cbmserviceguy
#3 Posted : Friday, September 9, 2016 6:56:04 AM(UTC)
cbmserviceguy
That model number is showing as a range...? Could you verify the model number and repost it please? That will help in checking what components are involved in the lighting situation.
BryceB
#4 Posted : Tuesday, December 13, 2016 2:19:33 PM(UTC)
BryceB
The light still comes on and off intermittently when the door is open. I replaced the button switch on one side. That didn't help. The light may work for days and then flicker or go off for a few days. The bulbs are in tight.
