My temp starting fluctuating in my frig. I ordered a new thermostat. It came in with the same part number, but the wires are in a different place. My old one had a blue wire on top and a red one one the bottom. The new one has the blades front and back instead of top and bottom. So shich wire goes where?
Groups: Expert
If they are both two wire thermostats, it shouldn't matter. Its 120 volts AC so it should work either way.
Just be careful with the sensing tube on the t-stat. Don't kink it or bend it too sharply.
