fireflynj
#1 Posted : 8 years ago
fireflynj
Hello,
I picked up this fridge used, so I noticed during moving it the back had rust, it looked like it was the water lines leaking running water down the back.
so I have it hooked up for a month now, but never connected the waterline for ice maker and is ice maker is turned off. Later I noticed ice on the back right start right above where there is a screw driven into it holding clamp for yellow and green line.
see pictures here https://drive.google.com/open?id...0wmhFYwlGRlQ5SzF2aEx5dUk
It was a cold spot there and the ice runs down from there, thinking it was condensation, I cleaned it up and put 1/2" foam insulation over this area.
but after a few days I hear clicking ever few seconds, and found the ice is back. (this is what it was under tin before, see second and third picture), I removed a portion of the rusty tin, so now more air might be the problem.
The temperatures inside is good, the clicking I don't know yet, and looking for inputs from anyone that might have some clues.
anyone know what is in the foam in this area? or could it be just air getting through the foam here, thinking of sealing it up next since the tin been compromised.
Thanks.
Frigidaire 3-door, tag inside says Electrolux home products, Model# LGUB2642LF4
fireflynj
#2 Posted : 8 years ago
fireflynj
I found the noise is coming from the upper icemaker and fan is not moving. There is ice build up on the inside as well as the outside of this area, So looking into it more.
found how to trigger the force defrost mode, press & hold fridge temp UP & DOWN for 5 seconds.
https://www.youtube.com/watch?v=PndzohEBOjU
fireflynj
#3 Posted : 8 years ago
fireflynj
I emptied it and help defrost the upper icemaker with a hair dryer.
https://www.youtube.com/watch?v=KsV-Zno92Fk
I verified the defroster wasn't 'open' with ohmmeter and took it apart and added a piece of tin to extend the defroster into drain. I also need to get new gaskets for the ice maker.
Then I sealed up the backside and covered it with 1/2" foam insulation. I think air was getting in through the foam too.
