Hi, I'm trying to find the correct part number for the oven igniter on an old Capri branded propane stove. Model#970-560511 Serial#5F001208
Groups: Expert
Your model number isn't coming up anywhere.
Do you have a picture of the part?
Well, I finally pulled the dead igniter out and found that it was a Norton 501A. I replaced it and the oven works fine. However I don't believe that was the original igniter as it appears to have been installed with plain old plastic wire connectors. Any thoughts? Just out of curiosity I may call Sears and see if they have a part number. It's weird that I can't find any hits for the model number...
Groups: Expert
Yeah, couldn't find it anywhere.
Just use ceramic wire nuts and it should be fine.
