Since we moved 7 months ago, the water dispenser on our GE refrigerator has been leaking after dispensing water. Just a few drips after each use, and then it stops, but it's enough that it fills up and drips on the floor eventually. Not good, since we have new laminate floors.
Here's what I've done so far: Replaced the filter and flushed the system for about 2 quarts of water. Replace the Dual Inlet Valve.
It did not drip before we moved, so I'm wondering if something was jiggled loose during the move.
Suggestions? I'd like to avoid having a repair pro come in if I can...
Thanks!
Seriously? No one has any suggestions at all?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
My experience with these has been the drip is from air in the "water tank or bottle" in the fridge. Try running a gallon or two of water out of it, usually a little air will come out too.
The air expands and contracts by the temperature. I could be wrong, but what have you got to lose? :)
