Helpme2016
#1 Posted : Monday, November 14, 2016 10:14:28 AM(UTC)
Helpme2016
Model JGBP79WEW1WW
GE PROFILE
Oven will not heat at all, at any temperature, even over 400 (in researching this I saw other people post that high temps worked for them). Stovetop and broiler work fine.
Side note: When I select the temperature and then select "Bake" the word bake keeps blinking instead of staying on like it used to. Then about a minute later the word bake stays on and the oven stays at 100. But it doesn't heat up at all, not even the slightest bit of warmth. Any ideas?
ThatGuy
#2 Posted : Monday, November 14, 2016 12:39:12 PM(UTC)
ThatGuy
Groups: Expert
United States
Helpme2016
#3 Posted : Monday, November 14, 2016 12:50:34 PM(UTC)
Helpme2016
Thank you for your response. I cannot see the igniter, it appears I'll have to remove the bottom panel. I'll have to do that a little later when I have some time. I watched the video link you posted so if it is the igniter at least I know I can fix it! Thank you!
