Dryer runs with heat when the start button is depressed and held down. When start button is released the dryer comes to an immediate stop. Which part is likely bad? Thanks for any help :)
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: ogroup85  Dryer runs with heat when the start button is depressed and held down. When start button is released the dryer comes to an immediate stop. Which part is likely bad? Thanks for any help :) Thank you for the answer and link. I have ordered a new motor and will see if that corrects my problem.
