My Thermador pd484ggbs has one of the 6 burners that will not spark. I can hear and smell gas when I turn on that burner and can ignite it manually but no spark from the range. All other burners work fine. This particular burner is used less frequently than all the other burners. I need to know how to troubleshoot and access the key components. Thanks.
Anybody have any suggestions? I think it's either the electrode or the switch but I can't figure out how to get at either. Is there's way to remove the burners from the top of the cooktop or lift the cooktop up to get underneath?
