The door no longer self closes; would this be the cam or the alignment. If it is the cam, how do I know if I need upper or lower?
Groups: Expert
Thank you, I loved the video. I have ordered the parts. These directions were for a whirlpool and I have a kitchenaid. The kitchenaid video shows removing the door completely; can i do it the way you did and keep the door in place? The kitchenaid also shows replacing a cam on top and bottom; what is your thought?
Groups: Expert
That's not me in the video. I'm just a guy that's trying to help out. I don't have anything to do with this site and I don't get paid.
Just trying to help. Its about the only thing I can still do.
Originally Posted by: smateja@earthlink.net  The door no longer self closes; would this be the cam or the alignment. If it is the cam, how do I know if I need upper or lower? On All coolers there should be two rollers or legs in front. You get some help and raise the front & you should be able to see the jack screws that adjusts the feet. Just screw the screws to LOWER the feet to raise the front and the door should close by gravity.
