AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Ice maker auger runs intermittently even when dispenser paddle is NOT pressed
Initially I had to replace the power control panel in the back of unit since the door of the ice dispenser was continuously opening and closing.
After that when unit plugged back in the ice maker dispenser auger would run intermittently and no one would be pushing the ice dispenser paddle.
So then I figured it was a problem I had probably created when I shut off the ice dispenser door from the front control panel prior to installing the new rear board so I could stop the ice door problem until the rear new board arrived. So then I replaced the front control panel in the left door.
Well even with both control panels replace the auger problem returned when I plugged in the refrigerator.
So the problem is now the refrigerator runs but the ice dispenser auger comes on intermittently when no one is pushing the dispenser paddle and tries to move ice when no one wants it
