I tried to unfreeze my water dispenser line quickly by using a heat gun and I might have overdone it. Now the water comes out in trickles only. I'm thinking of replacing the water line. I've been trying to find a guide on how to do this for this model but I was unsuccessful. Joined this forum to see if anyone can help. Thank you in advance!
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Thank you for responding ThatGuy. No, it's not the one at the back. It's the one in front in the dispenser where the water comes out when you press your glass to get a drink.
Groups: Expert
That's going to be a fun one. I've done that a couple of times.
Can you remove screws to remove the door seals and inner door liner?
Or is it glued together?
I'm not sure. I'm a little worried that I might not be able to put them back after.
