We have a GE dishwasher (model PDW8480J10SS) that is just about 10 years old. When we press the Start button, we can hear what sounds like the normal beginning of a cleaning cycle. However, there is no water!
Not even sure where to start, so I came here. Any guidance would be appreciated.
I'm comfortable doing the repair, just need to know what is broken!
Thank you, Shawn
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
I always start with the float/overflow switch. If it should get stuck in the 'full' position, it will shut off power to the water valve. part 308 on the diagram. Parts for GE PDW8480J10SS: Body Parts - AppliancePartsPros.comIf its OK, I check the water valve. See if its getting 120 volts during the fill part of the cycle. part 744
Originally Posted by: ThatGuy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I always start with the float/overflow switch. If it should get stuck in the 'full' position, it will shut off power to the water valve. part 308 on the diagram. Parts for GE PDW8480J10SS: Body Parts - AppliancePartsPros.comIf its OK, I check the water valve. See if its getting 120 volts during the fill part of the cycle. part 744 Thanks for the reply. It was actually a pretty easy (and embarrassing) fix. A couple of days ago, I did some work on my garbage disposal and turned off the water to the dishwasher. Once I turned it back on, the dishwasher magically worked again!! ;-)
