Ice maker makes ice fine but the "dump" cycle only releases half the tray of ice. Subsequent fill cycle fills the empty half and remaining water (which should go into second half of tray still filled with ice) overflows into ice tray. After a bit the ice tray is a solid block of ice. Do I toss the ice maker or is there a fix?
Groups: Expert
Is this a flex tray ice maker? Your model number is missing a few digits. I think the replacement ice maker is a more reliable design. Probably this part. AEQ57518210
Originally Posted by: ThatGuy  Is this a flex tray ice maker? Your model number is missing a few digits. I think the replacement ice maker is a more reliable design. Probably this part. AEQ57518210  No not that one. Ice Maker P/N is AEQ72909603.
Groups: Expert
