I have a frost issue going on right now and i have to manually defrost with a hair dryer every few days. I ran a diagnostics check from the control panel and everything including the heater and thermistor was fine.. I also saw the heater turned on and melt frost during the test. So, does that mean that the issue is with the electronic control board?
