Does anyone know where to get these parts? I have the same issue and it is now 2016. looks like the parts are no longer made. I'm looking for all 3
Originally Posted by: cradradc Does anyone know where to get these parts? I have the same issue and it is now 2016. looks like the parts are no longer made. I'm looking for all 3 As I said in a previous note, new limit switches didn't change anything for me, although you should be able to find them here (at AppliancePartsPros.com). I was not able to find a new control panel, but I was able to get mine rebuilt at Appliance Timer and Stove Clock Repair and Replacement - Ranges, Washers, Dryers, Dishwashers. I think the root cause in my case was a bad seal and heat escaping at the top of the door. I solved that by creating a makeshift latch the holds the door tightly shut. Good luck!
Originally Posted by: cradradc Does anyone know where to get these parts? I have the same issue and it is now 2016. looks like the parts are no longer made. I'm looking for all 3 Cradradc, The manufacturer no longer sells the part and we can no longer get it from any of our suppliers. There is no substitute for the part available to us and we don’t know of any other source for the part. You may want to try local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it. Try ********, Amazon or similar sites. Search by using the manufacturers part number. You cam also try a used appliance store, sometimes they have the same model or usable parts that you may use on your machine. Thanks,
The oven limit and fan limit switches are not available, and there is no alternate work around, seriously!? This is not rocket science! There must be some alternate temperature sensors that someone has found and applied to this stupid problem.
Come on, give me a break, anyone? :confused: :mad:
Amana ACS3350AS, 31933003, 31933004.
Originally Posted by: goatheardher The oven limit and fan limit switches are not available, and there is no alternate work around, seriously!? This is not rocket science! There must be some alternate temperature sensors that someone has found and applied to this stupid problem.
Amana ACS3350AS, 31933003, 31933004. Goathearder, Unfortunately, manufacturers are allowed to discontinue and delete repair parts as they see fit (as is in your case). Hopefully someone will have an answer for you. In the mean time you may want to contact local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it. Try E bay, Amazon or similar sites. Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model with a usable part, or access to a replacement part.
