Would I have better luck trying the lid switch next, or the clutch?
Joined: 6/13/2014(UTC) Views messages in topic : 781 Was thanked: 1 time(s) in 1 post(s)
If you hear the motor running when you shut the lid and the motor stops when you open it, the lid switch is functioning properly. If you are sure the tub is not spinning then the clutch would be next. If that's not it then a transmission rebuild would be next. Does the standing water pump out when its in spin cycle?
