my kenmore side by side ref pings. It will do this every hour or two. It goes ping ping ping for about ten seconds. other than that it work great.
Look at the condenser fan under the fridge to see if it's hitting a wire etc. The evaporator fan in the freezer could be hitting some ice. The internal compressor mounts could be making a noise when it comes on or turns off.
