AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Blinking Normal and Rinse Only lights and Time has two dashed lines
My dishwasher displays blinking lights for Normal and Rinse Only. The Time also displays two dashed lines. In this state, the dishwasher doesn't work. I've removed the power from the unit for a few days and then powered it back up. I was able to run a complete cycle, but once it was done, it went back into this same state. Once it's in this state, nothing can be operated or programmed.
Can you tell me what component might be failing and if it can be replaced? :confused:
Thanks!!
Dishwasher Repair
