I have a bottom freezer that forms a sheet of ice underneath on the inside which eventually spill over and melt on the floor. We have a Maytag MFI2665XEM7. I would love if this is an easy fix I can do. Please guide - step by step (I'm new to this) and I would appreciate any parts I would need to fix it or youtube videos that would be helpful. Basically, I need help :)
Thank you.
The good news is that you have a pretty simple problem. The drain line under the evaporator is clogged, frozen over and spilling into the freezer when the unit defrosts. The bad news is that it's difficult to get to. The following video will help you get at it and fix it. Please feel free to post any further questions you have. https://www.youtube.com/watch?v=VVBkMsXsn_4PS. Make sure the drain has good flow by dumping some water down it before you put it all back together. A turkey baster will serve you well in this endeavor.
