miksem
#1 Posted : Tuesday, September 27, 2016 9:12:15 PM(UTC)
miksem
RE: KUDC25CHSS1 Dishwasher type with vertical motor and pump directly under lower arm
Doesn't drain any water. Hose not clogged. Motor runs.
Besides the impeller, what else could cause the problem?
Is the motor supposed to reverse to pump?
ThatGuy
#2 Posted : Friday, September 30, 2016 12:56:11 AM(UTC)
ThatGuy
Groups: Expert
United States
The motor should reverse to pump out. When I used to work on these, I found all kinds of stuff stuck in the screens and impeller area.
Another thing I used to see all the time was a cracked impeller. It cracks and leaks water into the motor shaft rusting it and sticking the impeller on the shaft. It can make the job a lot harder.
The impeller kit is here, there is a video too.
Whirlpool 675806 Drain & Wash Impeller Kit - AppliancePartsPros.com
