bradf79
#1 Posted : Sunday, September 25, 2016 5:31:57 AM(UTC)
bradf79
I have a a PLEB27M9EC oven / microwave combination. My microwave is not working, the timer counts down and the light comes on but no heating or spinning. I figured out if I press on the door open button slightly, it will begin heating. I assume this means the door sensor switch needs replaced but I cannot figure out how to get the panel off. I've uploaded some pictures:
Imgur: The most awesome images on the Internet
I've removed the stainless steel think piece that wraps the control panel. I see no screws that are securing the panel from sliding up and being removed. When I pry on the right side I see The clips and it definitely looks like it must slide up to come out. I cannot slide it up because the black metal lip on the top of the unit is blocking it.
Does anyone have any experience on removing this panel?
Can anyone help?
bradf79
#2 Posted : Thursday, September 29, 2016 5:13:51 AM(UTC)
bradf79
Damn this is frustrating... I really don't want to just pry the panel off and break it, it's $125 just for it... Only thing I can see is removing the whole over+microwave and remove the top panel on the microwave so the control panel cover can slide up...
