Unit Won't Stop Cleaning !! Checked Water Supply Ok Checked And Cleaned Pump Ifs Ok Let Stand Overnite Started Again Found 2 Or 3 Sheets Of Ice Pilled Up On Top Of Cutter. Removed Them Nfound Brocken Wire On Cutter. Is It Possible To Fix Wire Myself? Or Must I Replace Entire Assembly.
Many Thanks
There is a restring kit for the cutting grid, but it is difficult to get it tight enough to properly cut. The entire grid comes as an assembly, but is well above the cost of the restring kit. So I guess the choice is your as to the direction you want to go. For assistance with part numbers, we would need a model number from the ice maker.
I Ordered The New Assyl Thank You
seems like once a yeaar its something. Now it won't make ice seems to be stuck in harvest cycle
