effinsyv
#1 Posted : Monday, December 17, 2007 4:12:14 PM(UTC)
effinsyv
I need to replace the heat seal on the top oven. This oven has a glass door. The seal is a thin rubber one that has flattened out over the many many years of use (30 plus). As we are only renting, a new range is out of the question. I would like to replace the seal but have a question.
The seal is not attached to the door, but appears to be sanwiched between the inner and outer oven compartments. Is there a way to loosen the space, replace the seal and tighten the whole thing back up?
kawfeeman
#2 Posted : Tuesday, December 18, 2007 5:11:03 AM(UTC)
kawfeeman
not going to be easy to find out info on a range > 30 years old...
