Washer will not continue cycle after draining. The pump is running and looks like it gets all the water out. I pulled the pump, cleaned it and checked the tubes for obstructions not finding any.
I put it back together and still won't cycle into rinse or spin. The pump just runs trying to drain till the main timer runs out and it stops.
Thank you for the help
