AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Estate Dryer Overheating. I suspect hot air leaking from drum
I had just replaced the motor only 1 month ago. I can't imagine it's time to replace it again.
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
True, but something is causing the motor to trip the over heat mechanism and shut it down. Have you run another test in the meantime to see if it would complete without shutting down?
Dryer Repair
