machouse36
#1 Posted : Saturday, September 10, 2016 4:07:14 AM(UTC)
machouse36
Have A Maytag Bravocs Mct Washer That After Selecting Cycle It Keeps Making A Clicking Sound Coming From The Bottom Of The Washer. Takes Forever To Start The Cycle And Sometimes Wont At All. My Wife Also Says It Doesnt Drain Well Either. I Have Checked For Clogged Pump, Even Pulled The Tub Unit Out And Cleaned That. None Of It Was That Dirty. The Clicking Noise Is Coming From A Synchronous Motor On The Bottom Of The Washer. I Have Removed It And Inspected It And It Appears Ok?
machouse36
#2 Posted : Saturday, September 10, 2016 7:19:15 AM(UTC)
machouse36
This fell on the floor while removing the shift actuator on the bottom of the washer. Where exactly does this piece go?
Its a bushing or spacer of some sort.
machouse36 attached the following image(s):
