musiclvr56
#1 Posted : Saturday, September 3, 2016 3:54:39 PM(UTC)
musiclvr56
I checked on my washing machine a while after starting a wash because I didn't hear anything and the "Locked" light was on and it was doing nothing
After a few minutes, I held down the start button for a few seconds to unlock it and opened the lid to find the machine full of water. Nothing I have done since then has been able to get the machine to start spinning or draining again. I emptied it with a shopvac.
Your advice and suggestions are appreciated. I am guessing it is something simple.
Thanks!
Karen
brobriffin
#2 Posted : Monday, September 5, 2016 6:59:43 AM(UTC)
brobriffin
Man
United States
Do you want to run a diagnostic to see what error codes pop up?
musiclvr56
#3 Posted : Monday, September 5, 2016 11:13:41 AM(UTC)
musiclvr56
There is only one button-no diagnostic codes-a very basic machine.
brobriffin
#4 Posted : Monday, September 5, 2016 11:19:13 AM(UTC)
brobriffin
Man
United States
There is a sequence of knob turns to put the machine in diagnostic mode which will display the error codes...
I can explain if you are up to it.
musiclvr56
#5 Posted : Thursday, September 8, 2016 5:32:42 PM(UTC)
musiclvr56
I cannot do diagnostics on my machine. A repairman looked at the washer and there was a tiny piece of dirt that got lodged in the fins under the drain pipe!
brobriffin
#6 Posted : Friday, September 9, 2016 11:04:13 AM(UTC)
brobriffin
Man
United States
Ok so are you back up and running?
Guest (4)
