6 Pages«<456
festeraddams
#51 Posted : Saturday, February 22, 2014 6:59:17 PM(UTC)
festeraddams
Rod, sounded like he had adequate water level, he had something else at fault. This particular dishwashwer pauses the pump momentarily to switch from lower wash arm to upper arm through the use of the check ball and the force of water pressure in the system. And since it is long gone, not really of any use since.
I agree the use of cleaners is a must nowadays, Dishwasher magic is the best cleaner to clean up a dishwasher, using minimal ammounts of detergent that is needed based upon how dirty the dishes are, rinse agents, and hot enough water in the inlet.
prorepair
#52 Posted : Wednesday, April 15, 2015 2:57:53 AM(UTC)
prorepair
After reading your problem I think that your should have to repair your dishwasher once.
AppliancesProInc Call VA:703-738-9050|DC:202-640-2178|MD:301-850-2847
is one the best service provider.
mkayi
#53 Posted : Friday, December 18, 2015 4:20:47 PM(UTC)
mkayi
Hi. This issue can be because of a small faulty part or valve. Usually, its a fast and easy fix if we can have a quick look. We provide same-day, satisfaction-guaranteed service and also warranty on all parts provided by us during dishwasher repairs. Our certified team offer low rates on dishwasher repairs. please visit: Home Appliance Repair | Fridge, Oven, Washer,Dryer,Dishwasher for more details or simply call us at (408) 649-5396 for a hazzle free , satisfaction guaranteed repair. W service in and around Bay Area.
Dean Haustead
#54 Posted : Tuesday, August 30, 2016 10:28:46 PM(UTC)
Dean Haustead
If your new or older dishwasher is not tidiness like it use to, here are several DIY tips to assist you fix the trouble. Whether your GE, Samsung, Bosch, Kitchen Aid, Frigidaire, Whirlpool, or Maytag dishwasher is not tidiness, all dishwashers job using the similar effective principle. The primary thing you should check is to shape out if the subject can be from hard water. This should be done before remove any of the part from the dishwasher.
tamarajbertrand
#55 Posted : Friday, September 9, 2016 2:51:00 AM(UTC)
tamarajbertrand
Thank you!
RogerBc
#56 Posted : Wednesday, October 26, 2016 12:55:27 PM(UTC)
RogerBc
Problem is with ur timer. Your model stops quickly, ball valve moves and
When motor starts again (1 second later) water gets pushed to top rack.
To check this without replacing timer you : when the wash motor is running,
You very very quickly open and close the Dw door. This will move ball valve and send water to the top spare arm. You can tell by the difference in sound. Sou like higher water pressure. If water goes to top, then replace timer.
If not, then you main motor is shot and has lost power to pump water.
Countrywide Appliance Rep
#57 Posted : Sunday, July 8, 2018 4:53:45 PM(UTC)
When you've tried multiple times and can't get it to work, it may be time to enlist the help of an appliance repair professional. Without proper testing equipment, sometimes you'll do more harm than good.
jake18
#58 Posted : Wednesday, August 1, 2018 4:07:27 AM(UTC)
jake18
Whether you require major repairs, need an emergency repair or simply want some help learning how to use your appliances, we can handle it all for you:
  • EMERGENCY/same day service available!
  • Major appliance repairs for all leading brands
  • Replacing control boards and compressors
  • Repair and replacement of dishwasher and washing machine pumps and oven elements
    And much more!
Our technicians have over 26 years of experience maintaining and repairing home appliances from all leading brands, including GE, Samsung, LG, Kenmore, Maytag, Whirlpool, Electrolux, Frigidaire, Amana, Bosch and more: Best Appliance at raynorappliance.net
Robertboyer
#59 Posted : Wednesday, March 11, 2020 2:55:25 PM(UTC)
Robertboyer
United States
We’re your one-stop-appliance-repair shop, offering repairs for minor and major problems on all appliances found in your home. Although our appliance repair service is a cut above the rest, we maintain reasonable rates for all of our appliance repair services. You can contact us for free consulting, our contact number is posted on our website. The link to website is attached below:-
Appliance repair concord
Guest (15)
6 Pages«<456
