I have a Frigidaire refrigerator model frt18sghwo gallery that is not cooling, evaporator fan starts and the compressor kicks in but not cools checked temperature control and replaced the defrost timer, checked defrost thermostat and checked good. the middle divider in front of the doors gets hot
Is the condenser fan running? Behind the unit by the compressor.
Just to add my 2 cents...
In which position is Moisture Reduction Switch? Normally it supposes to be Off.
