TML1
#1 Posted : Thursday, August 18, 2016 7:06:58 PM(UTC)
TML1
My GE Profile PEB1590SM1SS, just stopped last week. Initially thought it might be the fuse, but my youngest noticed if you press the pad to open door gently, the microwave works, the timer counts down. If you push too hard it reads "pause" on the display. The door latch does not look worn. The areas where the latches locks into, one on top and one on the bottom - I see a part in the bottom one, but nothing in the top latch spot. I defrosted food today holding the button for 2 minutes, so I know it works. Any help on what part I may need to replace would be greatly appreciated. Thank You
abadfish66
#2 Posted : Friday, August 19, 2016 5:10:45 PM(UTC)
abadfish66
Sounds like one of the door switches is bad. Part# AP2024367
TML1
#3 Posted : Saturday, August 20, 2016 3:02:44 AM(UTC)
TML1
Thank You very much for your response. I will be purchasing this part. Amazing how one can miss the ease of a microwave oven, even just to heat a cup of water ;).
Guest (4)
