the machine will fill with water but will not wash the clothes . I have replaced the door safety lid switch?
Originally Posted by: makenna15  the machine will fill with water but will not wash the clothes . I have replaced the door safety lid switch? machine will not wash the clothes any ideas
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Will it drain and spin if you advance the setting?
it will drain but not spin
yes the aggitater will work but turns freely
the aggitater does not work but turns freely
I had a similar issue which wound up being a broken/frayed wire down by the drive motor. Check to see if you are receiving power to the motor via the wire harness.
