Wondering if anyone has run into this issue before. We have an LG Front Loading washing machine, WM2250CW, only about 4 years old. It worked perfectly for 4 years and then one day when I pressed the power button, it played its little tune and then immediately turned off. Now, that's all it does. We've tried all the obvious things like unplugging it and plugging it back in and trying a different outlet. We think something may have gone awry with the electronic control board and replacing it should solve the issue. The part is nearly $200 though, so it would be great if someone out there with more experience than us could weigh in.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
