dta38tcb
#1 Posted : Wednesday, August 3, 2016 8:17:45 AM(UTC)
dta38tcb
Have a Maytag Dryer Model PYET444AYW Timer has been replaced, motor has been replaced and dryer will only run about 2 minutes then cuts off wait a few minutes and starts back. I have tested the motor by just running it on 110 with the motor wired only runs fine that way never shuts off. Door switch works and has been tested for continuity also. Cycling thermostat has been replaced and vent is clean, have even run dryer with vent pipe off does same thing.
Anybody have any ideas as to the cause of this problem?
brobriffin
#2 Posted : Thursday, August 4, 2016 4:34:45 AM(UTC)
brobriffin
Man
United States
