srbalsiger
#1 Posted : Saturday, July 30, 2016 8:31:39 AM(UTC)
srbalsiger
Whenever my GE is on the spin cycle, it sounds like a freight train and rocks quite a bit. It seems to finish the job like normal, but it makes quite a racket and I'm worried that some part(s) will eventually wear out from this. Would this part replacement help, or do you have another recommendation? I've heard it could be the bearing + outer tub, or the clutch. GE is model GTWN4950L0WS
brobriffin
#2 Posted : Monday, August 1, 2016 4:39:31 AM(UTC)
brobriffin
Man
United States
I agree with either of those possibilities. Check under the washer to see if there has been any water leakage! Pointing to tub seal and bearing.
