I have checked the thermal fuse, hi level temp, thermal cut off, tested the igniter, checked the flame sensor and cleaned the machine and vents. All in all I am still not getting any flame to heat the dryer. One thing I come back to is I am not getting electricity to the thermal fuse using my touch meter. Can there be a problem up stream from the thermal fuse that went bad that is causing this problem?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Please give us the model number which should be located just inside the door on the rim. It will be a sticker likely with the model and serial numbers on it. The number you gave us is a part number for the tech sheet you found inside the control panel.
