My Admiral electric dryer starts to run when the "push to start" button is pushed but stops 5-6 seconds later and wont try to start again until about a minute later. Exactly like a circuit breaker would do. My ohmmeter shows continuity at "thermal cutoff" and "high limit thermostat" . Any help would really be appreciated.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
When you start the machine do you hear a hum or buzzing sound before it starts? Your issue sounds like your motors windings are going bad. If you hear these sounds or it takes a couple seconds holding the button to start you likely need to replace the motor. Whirlpool 279827 Dryer Drive Motor - AppliancePartsPros.com
